StevenT that helped a lot! Thanks..
What about equalizer? i can't use it correctly..
what freqs do you cut and boost the most of the times?
(my voice is bassy..)
and what first? eq or comp?
Glad that helped.
As to eq, I ALWAYS
1. Get best eq at time of recording
2. Adjust eq on a track by track basis only (my hardware and software setups are both based on classic british eq) - I NEVER use a "Master" graphics equalizer.
3. Frequencies that usually need to be rolled off "a little bit" are HIGH HIGH on vocal tracks, and HIGH HIGH on bass guitar (sounds more smooth).
4. Since I only equalize using the mixer eq, the compressor/eq war is a non-issue for me.
Again, the best time to worry about eq is at the time of recording it!
That is the best place to capture the depth of a voice, the pulse of a kick drum, or the shreek of a lead guitar!
Something else to keep in mind regarding comressor/limiters.
COMPRESS Instruments
LIMIT Vocals
If you plan on recording for some time to come, invest in the best compressor/limiters you can get your hands on.
I use
Chandler Limited TG1 (
http://www.chandlerlimited.com/products/tg1.php)
I first came across these (actually the 12413 versions) at EMI years ago and I was sold - they are all I use.
The good news also, they have a VST version and it is AWESOME!
EMI/Abbey Road is actually using these in there DAW's too!
See:
http://www.chandlerlimited.com/products/plugin_tglimiterpack.php
It takes even the most uneven vocal and smooths and levels it to perfection and also controls any stray instruments with compression if I was sloppy in recording it, but also can really thump drums and bass!
Finally, since I don't know how you are recording, I will just add this - put your mic into a tube pre-amp prior to recording! Vocals stand out much better and more rich when tube pre-amped!
