grn
I figured since the other thread is so full of crap, we could add our own insight in to mixing. I am no expert, but here is what I do...
First and foremost, the most time and care must be spent on tracking. The air is your best mixer. Make sure you get a good sound going in. If it's for drums, I will get the best sound I can in the overheads and get a good stereo image, leaving room in the center for other instruments. For guitar, capture mostly the mid range frequencies and so on and so forth. Vocals are higher, bass is low. The point is to capture a good sound and don't think of it as a single entity, but imagine how it will sound in the mix once all the pieces come together. The distorted guitar may sound great, but then when you listen back it's got crazy harmonics and now you can barely hear the bass. Take out the lows and turn the distortion way down.
When it comes to mixing, I start only by adjusting the volume and getting the levels to where I need them to be. I go as far as I can with just the volume, then when I need more clarity I use compression - especially on drums and vocals. After I've done everything I can with volume and compression, I'm mostly done - because I captured it the way I wanted it to sound. Depending on the instrument, I may add just a hint of reverb... if you can hear it it's too much.
Unless there are crazy mistakes and/or errors, I'm mostly done. Otherwise I will go through and cut the bad parts out and make sure everything is lined up correctly. If the singer stopped a little short of holding out a note, I may extend it slightly - things like that. The most important part of the mixing process is tracking... if you have great musicians, you'll do alright. Study mic placement techniques.
