SteveM
Maybe I should put this in another forum, but can anyone direct me to some information or give me some input. I'm trying to figure out the pros and cons of using the mixer I have that is set up nominally for -10, with the Ampex tape deck I have, which is +4 outputs and inputs. I'm using an M35 mixer (I also have a M308) On the output side it is capable of putting out an unbalance -2 nominal output, but input wise has RCA inputs set up for -10. It also has transformers in the mic jack and a 40db pad. I'm wondering if it is not good to use that balanced input as an input from the tape deck.
Also the effects are set up for -10.
I know that I can use this board but I'm basically trying to see if it's maybe worth it to get another one. I just don't know what type of options are available on mixers and I'm having a hard time finding info on the web on this.
