famous beagle
Ok, so I've got the Yamaha RM804 mixer hooked up, but I'm having a hard time understanding how this mixer works. It's much different than the Tascam mixers (at least it seems to me) with which I'm familiar, and it's just not really clicking for me. I'm hoping someone can shed a bit of light. I've attached the manual here. It seems clear and succinct, but it doesn't give any information with regards to typical routing or setup.
I'm guessing that some of this might be just things that are labeled differently here than they are on Tascam mixers.
What's confusing me first off is the fact that there are two pan knobs (top and bottom of each channel) and two level controls (the fader and the "Stereo" knob) on each channel.
I won't be using this mixer at all for the preamps (at this point) because I have external pres. So I'll just be running the outputs of my Fostex 80 into the TAPE IN jacks for channels 1-8. I'll also have an FX processor hooked up to the ECHO send and most likely have processors (EQs or compressors) in the inserts as well. Those two things seem pretty straightforward to me.
I'm assuming that the PRGM busses can be used for setting up a cue/headphone mix, but I'm just not understanding exactly how this is done.
I'm also wondering if I could use one or more of the program busses for extra effects sends during mixdown.
Basically, I guess I'm just trying to figure out how I would normally set it up for the tracking process and then what would change for the mixing process.
Can anyone shed any light? Thanks much for any help.
