Mixer on sonar 3...
  • Thread starter Thread starter ARMAVIR
A
ARMAVIR
Hi..I dont have any external mixer & when i buy this software soanr 3 some peoples tald me << Sonar 3 including Mixer inside the sotfware ( HI, LOW, MID ) But i cant find any kind of mixer here..Any one can help with this ?
Not sure what you are asking, champ. "Hi, Low, Mid" sounds like you are describing the eq knobs on a mixing board.
What version of Sonar 3 did you buy - Producer or Studio? Producer does include an integrated eq panel (Studio edition does not). And both versions include a mixing console. Go to View > Console to open it up.
I have Producer.....I know about that, but let say i want add HI, MID or LOW on my audio tracks..So where is the mixer??/ Before i had external mixer, & i saw there all this options....
Some studio enginer recomend me about this setting << Kick drum 0db +3 eq at 50 Hz +1 db at 3khz -3db 275 hz No FX >>
Ok, how can i do this on sonar 3?
That's not a mixer, that is EQ. There are several ways you can accomplish eq adjustments.
I don't have S3 Producer Edition, but I'm pretty sure it includes "per channel" eq. You might have to launch the Console View in order to see it (see my previous post).
Maybe someone who owns Producer Edition can give you more explicit instructions (or perhaps look up EQ in the online help).
I go console yes, there is only EQ, & EFFECTS...I mean i search 10 times on HELP site about Mixer, but it did not show me regular mixer wich including HI, LOW, MID buttons....I have Parameters EQ & Graphic EQ, but i cant say that is mixer...They are just effects, so maybe i buy external mixer.....Thanks any way.
I think you are lost with the technical words.
A mixer takes several input signals and mix the signals into one (or more) outputs.
High, mid and low is in fact EQ. Not the best. The plugin-EQ in Sonar is still great. And remember, if you want an EQ IN THE COMPUTER, it will certainly be in software/plugin format.
A mixer doesn't need to have EQ, but it can.
The EQ in Sonar 4 is actually very good... I suggest you try it, there's no need for buying an external mixer (that is, if you really don't want to). :)
