W
Warwick720
Hello! I recently picked up a Mackie Micro 1202 for recording to ADAT. Decent little mixer for super cheap, but since I've had good results modding instruments, it seems like it'd be pretty easy and cheap to improve it.
First, I'd like to give at least four channels pre-eq and fade direct outs (Ideally 8, but for now I can use the inserts for the first 4).
Second, since there's only a 2-band EQ on each channel, I'd like to tweak cap/resistor values to tailor the EQ to the two most important frequencies I'll commonly use on a particular instrument. For example, any given channel could be permanently assigned kick drum duties, so for the LOW band I might leave the stock 80Hz or bring it up a touch, and change the HIGH band (stock 12k) to something around 400Hz. There'll be another channel designated for bass guitar, etc. As an added bonus, I can use better quality components!
The questions I could use a little help with are: How should I determine the component values involved? Is there a formula/software of some kind for this?
And are there any other modifications you could recommend?
Thank you!
Preston
Thank you!
Preston
