RawDepth
Let me know if the pictures are too large for your screen. Maybe I can upload smaller ones.
I started with a pair of legs robbed from an old Mackie mixer stand.
I reinforced them a little bit to support more weight and attached them with fat wood screws.
All the frame and support pieces are hardwood (Oak) for strength.
The upright ribs (in later pics) and shelves are softer wood for economy.
I used a variety of drywall, deck, wood, and sheet metal screws throughout.
I pre-drilled pilot holes for every last screw (in the entire desk) so no wood would split anywhere.
I decided not to use glue because I may need to disassemble this desk someday to move it through a doorway.
As an alternative I used plenty of screws.
The area beneath the mixer remains open for cooling and to accommodate racked equip.
I removed the plastic sides and original wrist support from the mixer so it would have that "built-in" look.
I wanted to be able to remove the mixer for service.
If I remove the top shelf from the desk, meter bridge slides up and out,
mixer slides out either forward or rear.
All the angles are based on the mixer surface and the tilt angle of the meter bridge.
I provided a handy little inlaid shelf for the mouse and keyboard for the computer DAW.
I shaped the end pieces by sawing a few angles and then rounding them off with the power sander.
All visible wood was sanded, primed, and painted with a satiny Latex.
The padded arm rest is simply a 2x4 with foam and vinyl upholstery fabric wrapped and stapled,
then screwed to the front shelf from beneath.
I wanted my computer monitors to be as low and as close as possible without blocking the mixer meter bridge.
They are bracketed to the shelf so they cannot fall.
I even have a row of large hooks across the rear to hold up cables.
There you go! Next, I'll work on upgrading equipment to better quality.
RawDepth
RawDepth
