Yes, mastering to Beta hi-fi was fairly common in the late 80's through mid 90's. Beta in particular was accepted at most mastering houses as one of the standard formats.
It does not behave like analog tape though because it uses audio frequency modulation (AFM) to lay down the hi-fi audio using the rotating video head. If the levels are too hot it does not compress like reel-to-reel, but reacts with harsh distortion more like digital.
I still have a Sony SL-HF350 Super Beta hi-fi machine that I used a lot for mastering years ago. It produces very clean, low noise recordings. Specs are pretty impressive. If you get one make sure the automatic level control is defeatable.
Frequency Response: 20 Hz - 20 kHz +/- 2 dB
Dynamic Range: Better than 80 dB
Wow & Flutter: Less than 0.005%
Harmonic Distortion: 0.3%
People also used VCRs in combo with a digital PCM device. But what I'm talking about here is just the hi-fi audio of the VCR itself.
I first learned of using Beta hi-fi in an October 1986 article in Electronic Musician Magazine entitled, "Mastering With Beta Hi-Fi in the Home Studio:
Champagne Mastering on a Beer Budget." Written by Tim Fluharty.
There is a lot of info on the web, but I haven't been able to find that article on-line.
You can use broadcast quality betacam tapes such as Sony BCT-30G, which are backcoated and equivalent to the highest-grade consumer beta tapes. Beta is technically defunct - nobody is producing new machines. But if you find a machine in good condition, new tapes are still readily available.
-Tim
