B bethanyb321 Member Mar 29, 2013 #1 hey if i import an mp3 into my sequencer and then export it to mp3, do i loose quality over the original mp3? thanks
Manslick Road Mar 29, 2013 #2 Depends on what happens in the sequencer. Are you changing eq and compression for example? If all you do is import and listen, simply save it, don’t export it so it goes thru another lame process.
Massive Master www.massivemastering.com Mar 29, 2013 #3 If you *export* it -- Even if you do nothing, it goes through the same crappy compression again.
J JeffroMixesYou New member Mar 30, 2013 #4 Save yourself the headache (and your 16K and up) and import it as .wav and export it as .wav.
