mixdown now or later?
  • Thread starter Thread starter muzicman8739
M
muzicman8739
Hey, I have a question, and I hope someone can help me.
I'm recording a singer to an 8 track digital recorder. I'm using synths for all of the instrumentation, and I normally end up using that many tracks just for the synths. What I want to know is if my mix will sound better or worse by bouncing the tracks down to two before recording the vocals?
If you do it right, it will sound better, if you do it wrong, it will sound worse. Unhelpful answer, I know, but it's the truth.
If you have a mixer with some extra inputs you can sync a sequencer to the recording, that way you get the extra parts of keyboards without having to bounce the tracks.
And anyway....less is more! ;)
thanks
hey thanks,
believe it or not you actually helped me quite a bit. I'm going to try your idea, and see how it sounds when I just automate the fade ins/outs on the sequencer.
Thanks again,
da muzicman
I don't know what kind of digital recorder you are using, or if you have access to editing but:
You could bounce your synth tracks down to a stereo mix, and record this mix onto another disk / tape, using the latter to record your vocals onto. At least that way you will have your original tracks all intact in case you want to make any changes.
