D
DLockwood
How do:
Just recently I upgraded my MD-4 yamaha to the MD-8. I also purchased a Eurorack 1804 external mixer for it. Now in the past, I would mic up my acoustic guitar with an Art tube pre-amp, from there I would run directly into my MD-4. Well the new 1804 has the pre-amps already built into it. However, when when I warmed up to it, I noticed a lot more hiss then when I had from the Art Mp. The mic I'm using is a Shure SM94 and I believe that this mic is sufficient to clean out unwanted noise. I wonder if the mixer is adjusted properly? Any ideas on this? Also is it necessary to mix the beginning tracks? Should I record these dry then later mix to taste? Any input on this would be appreciated. Thanks
DL.
DL.
