Mix And Eq-ing
  • Thread starter Thread starter Jimmy2002
J
Jimmy2002
Hi Im a newbi to mixing songs and eq ing so please could any point in the right direction heres some questions
whats Hi - Mid - LO Change i no lo is kider like the bass
how i can use the above to stop clipping when im recording
and if any1 eles could fill me in on any othe info to do with thuis subjet that you think i could do with knowing would be a great help thanks
Before learning to mix, you might consider improving your grammar......!
Anyways........ Mixing Article --> Mixing 101
To stop clipping when you are recording just turn the levels down a bit....or use a compressor.
Isn't there a newbie section for a reason?
Blue Bear must get about 10,000 hits a month from his (excellent) mixing 101 article. It's thrown around here like candy on Halloween.
Saves a lot of re-typing, since the same questions tend to keep getting asked over and over and over!!! ;)
clipping:
maybe a professional has a method of fixing this i dont, but the best rule:
dont clip to begin with. In the analog days, a little clip distortion was desireable, and tape saturation was a good hot signal that smeared the high frequencies together, and people liked it.
digital equipment doesnt react the same way...when the a/d conversion hits a certain point...it goes to sh!t...
dont hit that level in the first place...mic slightly further away, real-life compressor before it hits the soundcard or a/d unit.
great article.. I certainly found it very useful! In fact, I'm putting all my new found knowledge to work in the current mixing comp...
