Mini Mac
  • Thread starter Thread starter Petersonr70
P
Petersonr70
My question is. Can a mini Mac run the new logic pro software ? I'm new to the computer recording process. I've been working with a korg d1600. I know ancient technology. Lol. I want to go Mac, but working with a budget. Any advice would be GREATLY appreciated. Thank you
I don't know if I can help, but I bought a Mac Mini recently (first Mac I have owned after years of Windows PCs) - I use it with Pro Tools MP and it works great so far up to 24 tracks, and I also use various other software packages in the background with no problems. Mine is an i7 quad core with 8Gb RAM and a 1Tb HD. I run a LaCie Firewire external drive to hold my PT files. I know of others who use the Mini with demanding software applications commercially.
I bet if you looked up Logic's system requirements and checked them against the specific Mac Mini you have in mind you would answer your question much faster than the forum could (especially since you didn't specify any specs about the computer)
minis are very powerful. Wont have any problem with logic.
As with any computer, you want to put more ram in it (cheap $60 no-brainer upgrade)
And you want another drive or two (daws work best - ANY daw - with multiple drives)
OS, apps and plugins on boot drive
sample libraries on second separate drive
audio projects and tracks on third separate drive
I'm currently running a 2011 Mac Mini Server as my recording rig. I run Logic Pro 9 and it runs fantastic! I record pretty much all instrumental Rock stuff - drums are programmed using Logic's Piano Roll Midi Editor and procressed with Steven Slate Drums v. 3 (which uses the Kontakt player - pretty resource intensive). Most guitars and bass are run through Amplitube 3 on it's hi res setting, which is also pretty resource intensive - then into MixIR - which is a means by which to add speaker cabinet/mic emulations to my modeled amp tones. Then quite a few plugins. There are always quite a few guitar tracks so all these plugins add up. Then Drums, Rhythm Guitars and Lead Guitars are all sent to their own respective sub mixes, Aux's are set up with various plugins, etc.....
The Mac Mini handles it all beautifully! With all of those guitar tracks running through Amplitube then Speaker Cab impulse responses, occasionally I'll get an overload error. This is easy to get around though, Logis allows you to 'freeze' individual tracks, which basically does a temporary mix of each track selected with all the plugins applied. This way on playback it's just playing back a static audio track, much less processing overhead that way. Then if I need to edit audio or plugin settings on one of those tracks I can simply click off the freeze button, work on it, then click the freeze button again to refreeze it.
When I was researching whether going this route would work, I hear quite a few people referring to the Mac Mini Server as Apple's best kept secret. After using it for over a year I'm inclined to agree. Potent little machines...
The only reserve I have is that from what I understand, the current MMS comes with 5400rpm drives. That's not a good thing. But from what I've read, the hard drive in a Mac Mini is pretty simple to replace. I haven't done it but installing RAM IS simple and quick. Word of advice, order your RAM elsewhere, Apple charges way too much to upgrade it. I think the newer Minis hold up to 16gb of RAM (mine, being older, maxes out at 8 gigs but it runs great on 8 gigs). You can search around online and find that for a Mac Mini for a little over $100 (may be less, I paid $39 on amazon for 8 gigs of Mac Mini RAM in January 2012). And like I said, it's dead simple to install.
So I say go for it, you won't regret it, even if you do need to replace the drives with 7200rpm (HIGHLY recommended) or even solid state drives, but they're much more expensive.
Enjoy!
