Mindprint Envoice and EQ
  • Thread starter Thread starter ColdAsh
C
ColdAsh
I've been playing around with the EQ on my envoice and quite frankly it doesnt seem to make a bit of difference. I can have the boosting or cutting as much as possible and its sounds the same weather they are on or off. Has anyone else had this problem? Im using headpohnes atm but i can hear the differnce FAT EQ makes in logic.
Did you engage the EQ circuit? You have to push a button.
Yeah thats what i mean by it sounds the same when its on or off. I dont notice the change when its engaged/disengaged.
Hmmmm. I can hear mine. It's possible you have a problem with it.
There is separate button to engage/disengage each of the three eq sections.
The unit I'm using works perfectly. I'd get it checked out.
Mark
Theres a button all the way to the right called "effects"...press it.
Cheers JuSumPilgrim, boy do i feel stupid. Does this also effect whether the compressor is on or off, im guessing it does.
