midi to WAV
  • Thread starter Thread starter yaron_c
Y
yaron_c
Hi,
My DAW includes Delta66 , SB Live Value and Cubase
VST 3.7. My question is:
In Cubase, do I have to be able to see in Audio ->
Inputs also the SB inputs? because I want to record the
midi files to wav with SB. I know this issue was
discussed here before but I could not be able to do so.
Do I miss anything, do I have any alternatives (except
to physically connect SB outputs to delta's inputs).
Thanks and sorry for my English
This will be a total guess, because I have none of the hardware or software you listed, but I do have a Delta card.....first get the midi track into cubase where you want it....set up another track to record and, assuming you can choose, set it to record from the Delta Monitor Mixer.....if there are tracks in the file you have open other than the midi track you want, mute them....hit record...while the midi track is playing, the audio track you are recording should be picking it up.....
again this is a total guess.....
disclaimer......Gidge will not be responsible for any damage to products or loss time as a result of his careless advice......
