B
B1&B2
Hi,
I know this question has been asked a thousand times before, but I've never seen a REALLY good answer. I need to turn MIDI into a wav file but without sending the signal out of my PC. I'm using an AWE64 (internal synth and Reality), a Delta-66 and Cubase VST. So... is there a way to either send the AWE's output to my Delta (internally), or get the Delta to record it's own outputs when using Reality? Please don't tell me to run a lead from the AWE to the Delta's inputs, cause I've tried that, and although it works fine, I still get that lovely AWE64 hiss and skwelch!
The reason I need to do this when using Reality & VST is that using the 'capture' option results in slight tempo drift, so when I then import the wav into VST it eventually ends up playing out of sync. The wav files turn out lovely but they're just not the exactly the same tempo as VST.
Sorry if this is all a bit mixed up and confusing, but I'm feeling a bit mixed up and confused
