My synth is a cousin of the JV-1080, but I'm pretty sure that the command structure as to stuff like performance mode is different.
On my Sound Canvas (SC-88), performance mode refers to whether the input is interpreted as monophonic (one note at a time) or polyphonic
and whether the sounds are mapped to a drum set or an instrument.
I've got sound going through but I just don't seem to get it:
How do you orchestrate a song using MIDI?
For example...I can "record" the piano part with JV1080 receiving on CH 1. And then I "record" the bass part, and switch the JV1080 to CH 2, but now I lose the piano part while recording the bass or playing back. OK, I understand this must be becuase its only sending to CH 2....BUT then HOW DOES MIDI work?? I want the Logic Sequencer to send a bunch of commands to different sounds on the JV1080!!!!
WHAT AM I DOING WRONG??
WHAT AM I NOT UNDERSTANDING????
WHAT DO I DO???
I"M DESPERATE!!!!
PLEASE HELP!!!!
Make sure that you're talking about <channel> one and two and not <port> one and two. Each port has 16 channels, but not all synths can play two ports, and the selection inside your software is different for these two options.
If you've got 2 ports you should be able to play 32 different channels. Try this:
Just create some MIDI inside your SW on multiple channels with different instrument patches and play it back. Do you get more than one channel playing on the JV1080?
Well, actually, someone I was talking to a little while ago said that it might have to do with me using the Performance Mode on the JV-1080....do you use a JV-1080 or anyone else out there use one? Cause I could use some help on the basics of setting up a Performance. Thanks for your help.
