MIDI sound module/delta66 & SONAR question
  • Thread starter Thread starter amt7565
A
amt7565
I am using DELTA66/OMNI with SONAR. I am using a Roland JV1010 as my sound module. I can listen to the module through SONAR. But when I attemt to record it on SONAR to audio, I don't see the tracks light up and the sound does not get recorded. I am still able to record my guitar, but not the sound module. I have the sound module connected to the "effects return" on the OMNI.
On SONAR I have tried selecting various parameters as the source but no luck. I have also played with the "patch bay" on the OMNI.
Any ideas anyone? Thanks :D
Umm, I'm no expert. but don't you think the JV should be feeding into 2 of the inputs (non mic-preamp) and not the FX return? If the FX return is not a valid recording source in Sonar then of course you are not going to record anything. I don't think it would be anyways because whatever comes through the FX return is routed to an input anyways (so you can control the FX wet/dry mix). The only other option if you need to keep the JV on the FX return would be to crank up the FX return level in the Omni mixer hardware/software on a specific channel and record that channel.
