midi recording problem
  • Thread starter Thread starter Imaginator
I
Imaginator
Hello everyone,
i just bought a Tascam us 1641 usb interface and the problem is that when i record in nuendo(ver 3.2), i have latency, only to the recorded midi.There is no latency at all to the sound i play with my korg x50 as midi controller
The ammount of latency can vary from small to huge.
I use the latest drivers/firmware from tascam
I googled for this problem and i found two solutions.One was to enable use system timestamp in the device setup and the other solution was to find a file called "ignoreportfilter", then cut it out and paste it one level up in the Nuendo root folder.
Both helped temporarily, i mean for a few minutes.After two or three small recording attempts, latency was growing bigger and bigger...
Any suggestions?
my system is
2.4 Ghz intel core duo 2 (6600)
ram 2Gb
motherboard Asus P5Q Deluxe
i use windows xp pro sp2
What are you using as a midi playback device? In other words, what is midi usng to generate the sounds you here?
If you are using the PC's internal GM wave table, that could well be a source of your latency problems.
Do you have any VST instruments? Try these and see if there is latency.
Or try an external device, like a sound module.
and there is latency only to the recorded midi
i hear exactly what i play in time but it is recorded with latency
