MIDI Recording DR-770 Matching to Time Signature
  • Thread starter Thread starter LewKellogg
L
LewKellogg
OK, I'm missing something really basic and could use some help. I'm trying to record the MIDI from a DR-770 drum module. I can get Sonar 3 to record the notes. I can't get the time signature and tempos to match.
I set the tempo on the drum machine and in Sonar to the same thing (160 in this case). When I am recording everything sounds fine. When I play back the drums are at least 1/2 speed and out of sync with the measures. I've tried different time signatures amd tempos to the point that I'm not sure I understand them anymore
Can anyone one walk me through this or give me suggestions on where to look? As I mentioned, the MIDI notes record just fine. I am using MIDI sync so Sonar statrs when I start the DR-770 and thus the first note at least is at the beginning. However, all of them are just and out of sync on play back...
Please do NOT double post, buddy. Check Cakewalk forum.
Jaymz
Thanks for the heads up and the response in the Cakewalk forum. I found the problem.
