N
Noctem
Hello, all!
I have a problem that is probably a pretty easy deal to solve. I just can't find the solution myself. I am using Cakewalk Sonar 2.0XL and a Audiophile 2496 soundcard. I used to use a Soundblaster Live! and Cakewalk 9.03.
My problem is that when I had the old setup; I used to have the onboard MIDI-sounds as metronome when recording MIDI. I just checked OPTIONS/PROJEKT/METRONOME and choosed port #2, which was the Soundblaster Live! MIDI sounds. Port 1 was the actual MIDI port where I connected my synth.
So, with my new setup, I can't find any way to use the onboard sounds as metronome. I just got DELTA AP MIDI and Microsoft MIDI Mapper as available MIDI devices. But The Delta MIDI is busy recording incoming MIDI eventes from my synth and the Midi Mapper returns nothing but silence.
I was thinking that the Midi Mapper is actually playing the ticks, but in order to hear it I need to check some not-yet-found box in the control panel?
I know there is nothing wrong with the drivers or the software, because when I play a .MID file in WinAmp, it uses the Delta MIDI sounds.
This card is way to expensive to have me recording with the speakers on LOOOOOW volume while paying attentino to the internal PC speaker as metronome.
Anyone of you guys who knows the solution to this problem?
