thebigcheese
"Hi, I'm in Delaware."
I got a MIDI Mate for free the other day and I would like to configure it to work with Amplitube so that I have a nice, silent way of practicing, but without giving up the convenience of stomp switches. So my ideal setup is to run the MIDI Mate in Controller mode and have the bottom row of buttons recall specific presets (like switching channels on an amp) and the top row should switch effects on and off. I've got the top row configured, though by default it seems to switch states backwards (that is, I have to set the Min value in Amplitube to 100% and the Max to 0% so that when the light is on on the floorboard the effect is on), but I cannot for the life of me get the bottom row up and running. In theory I should be able to assign a program change to a specific preset in Amplitube, which is great because that's what the bottom row is supposed to send out, but that doesn't seem to actually do anything. Here is what I am doing:
1) Open the desired preset.
2) Click the MIDI button.
3) Under the "Preset" tab, change the Program Change to the desired value (say, 03 to correspond to button 4 on MIDI Mate).
4) Close window, hit "Save" to save settings.
Then I move to a different preset, hit the button, nothing happens. I also notice that the current preset shows the same Program Change value under the MIDI menu as the one before. And on top of that, if I change it here, it stays at the new value when I go back to the other preset.
I have also downloaded MIDI-ox to check the output of the MIDI Mate and it does seem to be doing what it's supposed to be doing. That is to say, when I hit the top row, it sends out CC. When I hit the bottom row, it fires off the appropriate program change followed by a bunch of control changes (presumably it is resetting the top row of switches, since the numbers correspond to those).
What am I doing wrong here?
