F
fatemonkey
i have a delta 66 that i've had for years, and just recently got working in a satisfactory manor, thanks in part to your advice, thanks guys. I'm currently in college and don't have alot of room, and it looks like at some point i might have another computer with which i'll need to record. I thought if i got a firewire 410 from m-audio, i could have the 2 preamps (which I NEED!) and i could use the 2 preamp ins in combination with the line level inputs on the delta when i record with my band (most of my work is solo but that would be nice). This would also give me an interface i could take between computers.
i also need a midi controller and i thought i would get the oxygen 8. then i found out that the ozone has 2 preamps built in, and could satisfy both of my needs. but the fact that it can't be usb powered would be a bummer and if you're using both inputs i thinkyou have to decrease the quality (its only usb) what do you think?
should i go for the seperate firewire 410, or try to save some money with the ozone...i'm trying to think long-term
thanks
thanks
