H
hokie
Hey guys- I'm new to this forum and did a little searching about for this issue but no dice. Any help would be appreciated.
My setup is as follows:
td-6v MIDI out --> lexicon lambda usb interface --> cubase le
cubase le --> lexicon lambda --> td-6v MIDI in
I've been able to record a midi track from the kit into cubase; however, when I hit play in cubase I want my td-6v to play back the incoming data.
My ultimate goal was to be able to record a drum track via midi, copy that midi multiple times and create a midi track for each drum, then use the td-6v's 1/4" outputs to record that into cubase so I can do EQ'ing and processing on each individual drum.
My MIDI settings in the brain are as follows:
Note Chase: On
Local Control: Off
Sync Mode: INT
Ch10Priority: Kit
Pd1DataThin: 1
GM Mode: Off
RX GM On: On
Soft Thru: Off
TC PC Sw: ON
RX PC Sw: ON
To try to narrow down the problem, I tried the exact same setup as above with my keyboard and when I record a midi keyboard track then play it back through cubase, the keyboard sounds.
I'm probably missing something dumb/small but any help will be appreciated.
Note Chase: On
Local Control: Off
Sync Mode: INT
Ch10Priority: Kit
Pd1DataThin: 1
GM Mode: Off
RX GM On: On
Soft Thru: Off
TC PC Sw: ON
RX PC Sw: ON
