Porter
aka WookieMan
Hi everyone,
I'm not too sure which discussion to put this on so it's on a couple.
I'm putting together a CD with my Fiance as a Christmas present for our family and friends this year. She's has a great voice and she loves the 'Big Band' sound. We are currently working on the first track, the Peggy Lee classic, "Fever". I want to set a high standard and set it higher on every future song.
I've got a MIDI file for a song which She wants to record which I think was created/written from a score for the song. There are 4 trumpet parts, 4 trombone parts, bass (which I'll actually play myself) and drums and a couple of other brass instruments. I'm planning on using ProTool's Free so I can have it as a slave to the Roland 840EX (4 inputs) allowing me to play the MIDI files numerous times with a single instrument playing each time to get the separation of the instruments. I know that this will take time, however, if it sounds better I'm willing to spend that time doing it. The first question is: Does anyone know if that can be done, having ProTools Free as a slave to the 840EX?, I haven't used Pro Tools that much before and if it can be done I'll work out how to do it.
I have a Roland JV-1010 which I'll be using to produce the sounds. I want to make this recording sound as close as possible to that of a real band. Here's what I'm thinking:
Record each instrument individually, ie each trumpt track individually using only recording the time that they are playing (to save space). Now when bouncing them I'll change the EQ settings on each of the tracks slightly so that they sit differently in the mix and they sound different to each other, giving the impression that the same person (or computer) isn't playing it.
I think that I'll run the drums through the JV-1010. My other option is to play them through my SR-16. Any opinions on which one would be better to get that 'big band' sound?
As for recording the vocal and mixing it, at what stage should I mix it? Should I mix it with just a drum and a bass or should I mix it after I mix the brass section?
Before mixing the song and classing 'stereo' as 2 track, I'm probably going to be looking at 13-17 dry tracks. I'm probably going to be spending more time on bouncing than I did recording my previous 4 track song. Should I attempt to use MT1 mode or should I play it safe and use MT2?
I would love to get any suggestions or feedback for what I'm planning on doing. I don't know how Copyright works with this, however, once it's finished and if no one tell's I'll post it on my homepage so you can hear the finished product.
Thanks,
Porter
Thanks,
Porter
