midi and sync problems
  • Thread starter Thread starter bryan jones
B
bryan jones
I've tried reading my manules on this subject, but I still can't understand how to get my vs 1880 to play my roland sp303 sampler and my yamaha rmx1 to play in sync, or even play at the same time. I really don't understand how to read the chanles or how to match them up. Can I get some insight on this subject?
Help me understand this just a little better. Are u trying to use your VS 1880 to run 2 different peices of equipment at the same time? So in other words, all 3 working together controlled by 1 machine? Or is the Yamaha RMX1 (which I'm not sure what that is? Keyboard?) seperate?
It's not clear to me why you posted this in the Cakewalk Forum. Is any of your equipment connected to a computer in any way?
midi and sync. problems
Well, I posted my subject on cake walk, because I am planning to use my computer w/ all of the equipment that I have and do additional mixing through Cakewalk 2002 home recording. I want my vs1880 to be the master to my other instruments through midi
connections. I just don't understand how to change or match up the midi channels so that everything would play in sync. I did figure out how to make my Yamaha rmx1 seq. start playing w/ my vs1880, but not on time.
I don't own any of this particular equipment, but here's a few pointers.
There are two kinds of midi sync. MTC which is also SMPTE and Midi Clock. You have to pick the one common to all of the devices.
Generally, and I think probably certainly, MTC is the only option with an Audio device that must be slaved but either can be transmitted by a Master - Midi clock isn't fine enough to slave an audio recorder. Cakewalk 2002 will only transmit Midi clock so it's usless as a slave to the vs but it should be able to control the sequencers.
By selecting Midi clock in the VS sync menu and arranging it to feed the other two boxes midi ins should allow them to follow the VS transport. But there can be other settings to make. Find if you have to enable...
1: Clock in
2:MMC (midi machine control) this is the Transport button control.
3: SPP (Song Position Pointer) which ensures the devices start and stop at the same place in the song and the slaves will follow locators on the master VS.
If you need a pc sequencer that can also follow your VS then you will have to upgrade to Sonar which can sync to MTC or Midi Clock (provided it's a midi only sequence). To use the sequences in the boxes, it's recommended to record them into the pc sequencer and have this drive them as sound modules (External note in).
Unfortunately, the other boxes you have would simply have to act as midi sound modules as Sonar will not repeat the MTC codefrom in to out or convert it to Midi Clock.
The best way to drive more than one midi sync slave would be to get a midi thru box which acts as a Y cord to feed one midi out from the vs to each boxes midi in.
Under MTC, there is a delay while everything Syncs up and it's usual to enter an offset time - say 00:00:02:00 (2 secs) in each devices sync menu.
It's complex.
