M
mpisani
I have an old Ensoniq MR76. I currently have an audio interface with MIDI In/Out ports. If I get a new interface, is it worth getting one with MIDI ports or do MIDI to ¼" cable adapters work just as well?
I agree with Ray, just makes for a neater setup to have DIN ports on the interface. If you are looking at a basic 2in 2 out or 4 in 4 out I can strongly recommend the MOTU M2 or M4. Almost top end spec and very stable, low latency drivers.I have an old Ensoniq MR76. I currently have an audio interface with MIDI In/Out ports. If I get a new interface, is it worth getting one with MIDI ports or do MIDI to ¼" cable adapters work just as well?
Well Rob, I have to admit that I have not seen any equipment reviews with 1/4" MIDI jacks! However, there is an increasing use of 3.5mm TRS jacks for MIDI. The usual reason is space but I suspect jacks might also be cheaper now? DIN is after all pretty obsolete!MIDI to 1/4"? MIDI is data, 1/4" is audio? A bit confused to be honest.
Just get a Midi to USG Adaptor and be done with it.I have an old Ensoniq MR76. I currently have an audio interface with MIDI In/Out ports. If I get a new interface, is it worth getting one with MIDI ports or do MIDI to ¼" cable adapters work just as well?
I thought of that as I was typing the question. I'm not sure it's MIDI to ¼". It night be MIDI to USB or something but it's some type of connector if you don't have MIDI ports. But I'll probably just look for an interface that has MIDI ports since that seems to be the consensus.MIDI to 1/4"? MIDI is data, 1/4" is audio? A bit confused to be honest.
Indeed and the VAST majority of MIDI devices, KBDs drum machines, use DINs. IIRC you can "daisy chain" about three?You don't just want to connect a midi device to a computer, but to other midi devices too.
I think it’s 4 when everything is perfect - before you start getting latency and other conflicts.Indeed and the VAST majority of MIDI devices, KBDs drum machines, use DINs. IIRC you can "daisy chain" about three?
