Michael Jones
OK, here's the task:
How do you mic a grand piano, and come away with a "Stellar" sound??
Now, Here's where I'm at and what I have done:
Equipment:
1 - 6'-2" Boston Grand Piano
2 - Neumann TLM-103 mics in an "X-Y" config. splayed at 120 degrees, and placed above and behind the center of the harp about 22".
1 - Shure SM81 set off in the room and pointed at the wall to capture reflections.
1 - ART Pro MPA Microphone preamp.
1 - Yamaha O1v digital mixing console.
All of this runs to PC where I use "Steinberg's" Nuendo recording software to record at 24 bit.
Except for the effect of the tubes from the ART, everything is recorded more or less dry. All this in an acoustically treated room thats about 22'x24'.
To listen to a sample of this recording using the above equipment/technique, go here http://michaeljones.iuma.com
and listen to "Seeing You".
After recording, I add just a small amout of reverb.
The biggest problem I seem to be having, is poor definition in the low end.
Should I consider different mic's, is my technique poor, do I need to consider compression, eq,,,,,or have I simply choosen a very difficult instrument to record?
Any advice would be appreciated. It just seems like with the quality of equipment that I have, I should be able to walk away with some stellar recordings.
Thanks in advance.
Equipment:
Thanks in advance.
