microphone sensitivity
  • Thread starter Thread starter makaveli_mo
M
makaveli_mo
hi guys Perhaps you may be able
to lend me your help analyzing this microphone.
The intended purpose is to pick up slight whispers with the microphone placed at the neck line.
Based on the sensitivity Sensitivity @1 kHz (dB re 1V/1PA) -34.0 +/-3 dB I have determined the sensitivity to be 19.526 mV/Pa. In your opinion
do you think this microphone is sensitive enough to pick up slight whispers and relay them to a device.
Please find attached further details of the microphone:
ype Omni directional electret
Output impedance @ 1 kHz 4,4 kΩ
Requence response 100 Hz.10kHz
Amplifier current drain Max 50μA
Supply Voltage 1.5 - 10.0 V DC
Temperature range (operating) -10° C To +60° C
Thank you for your assistance. This is a matter of slight urgency so I do appreciate your support!
