easlern
Boredom artist
Hi all- I admit I know nothing about electricity except that you shouldn't touch it and you shouldn't get it near water.
I just got a Presonus tube preamp for use with my mic, a Seinhesser(sp?) 816e, but there's a problem with it. When I run the mic through it, I get a terrible humming that gets worse when I touch the metal part of the microphone. I'm pretty sure this is a grounding problem, since I'm using an XLR->1/4" cord from mic to preamp and a 1/4" cord from preamp to sound card (X-Fi Platinum, in case that's useful info). (The preamp has one XLR and one 1/4" inputs, and one "balanced" XLR and one "unbalanced" 1/4" outputs.) I haven't tried using the "balanced" output because I don't have an XLR->XLR cord, but I don't see how that would help, since the preamp seems to be ungrounded anyway.
Assuming this is a grounding problem, I'm not sure what to do because my card doesn't have an XLR input and the preamp itself uses a standard 2-prong (ungrounded) AC-adapter. Are there preamps I can get that take an XLR input and output a grounded 1/4"? Is it possible I can take a metal wire and tape it to both the microphone body and a metal part of the computer? Maybe the problem has nothing to do with "grounding" at all? Maybe I am hopelessly ignorant of electricity and should stick to acoustics?
