darrin_h2000
Banned
Im curious if not having the hole in the spot that normal guitars have it changes the placement . I have an exelent sounding guitar with F holes, and even though It has pickups I would like to use th L5 for accoustic work.
If you're talking about an old Gibson L5, yes, the placement would be a little different. The radiation patterns on an arched top are very different than a dreadnaught. The high end is straight out from the body. Very like a loudspeaker; highs in the center, warmer more mellow sound as you move towards the edges. It's pretty hard to mic an L5 badly as long as you pay a little attention to what you're doing. Great guitar.darrin_h2000 said:Im curious if not having the hole in the spot that normal guitars have it changes the placement . I have an exelent sounding guitar with F holes, and even though It has pickups I would like to use th L5 for accoustic work.
Is this jazz chordings you're using it for? The Gibson L-5 was originally designed to cut thru as a rhythm instrument in a big band - without amplification. Put a little distance between the guitar and the mic and the sound will come alive. Close miking with a cardioid is okay, but different spots will produce different sounds.darrin_h2000 said:Thanks, Ive been putting a 603s on the 12th fret angled towards the headstock like I typically would a regular guitar and It occured to me that It may be different. Any suggestions that may give me a better sound?
