Mic'ing a Cab
  • Thread starter Thread starter xpunkskaterx
X
xpunkskaterx
I have a Vox 4 X 12 cab. I have an SM57 which I know is probably the best mic to use. However, are there any special techniques for getting a better sound from the mic? I believe that it is better to tilt the mic so it is not facing straight into the cone. I have some other condensors too, would it be beneficial to throw one of those behind the 57?
Mic placement and angle both play important rolls when recording any cab. In addition to placement you need to consider which speaker you are going to mic. For some reason (unknown to me) one speaker will always record better than the others. Sometimes a 4X12 cab will sound best with a single mic placed a few feet in front of the cab, this depends a lot on your room, how loud the amp is, and how much isolation you need for the cab. Try various mic placements (little changes do make big differences) until you find the legandary "sweet spot" where a cab sounds as good as possible.
For now, work with a single SM57. Multi-mic setups add a whole slew of other problems (phase cancellation, for one), so initially it's probably best to learn the fundamentals of positioning with just a single mic, and add more complexity as you go on. and, honestly, the majority (probably - no hard numbers to back this claim up, but I'd be shocked if it isn't true) of guitar recordings you've heard were probably done with a single SM57.
After that, experiment. There's as many good ways to record as there are good recordings, and the best way to get good results is just to spend a lot of time trying different positions.
The way you've suggested (point a mic straight at the center of the cone, maybe 2" back, and then angle it a bit so it's parallel with the 'wall" of the cone) is certainly a valid way to go (I think it's Slipperman's go-to in that excellent tutorial of his floating around the net), but it's definitely not the only way. I tend to point a SM57 just shy of 2" back, parallel with the grill of my cab, and a bit off center, closer towards the edge of the speaker cone than the center.
That said, the best way to go here is to fire up your amp, strum a chord, and while it sustains swing a mic back and forth in front of a speaker while listening back through headphones set for real-time monitoring.
One word of caution - initially your ear is going to prefer brighter, edgier sounds, since they're going to be percieved as louder and more powerful. This isn't really true, and a lot of the time it's the darker sounds that work better in a mix.
Good point! It is important to check the sound in context of the other tracks to avoid Solo Syndrome.
It's also a question of re-educating your ear, too. Try this - record a take against bass and drums with a tone that you think sounds good, and then with one that you think sounds a little too dark. Walk away, listen to some other music for a while, and then come back. Odds are the first take will sound fizzy and shrill, while the second will sound more balanced. Keep doing this, and eventually you'll consistently be choosing a tone that works well for your initial mic position.
Really, mic positioning and selection is about the most powerful form of EQ you have at your disposal, but also (for better or for worse) the thing that's going to make or break the tone in the mix. It takes a lot of practice to get good at it, but when you do it'll seriously pay off.
Someone should really start a thread about this, or write an article or something...
