Nitemare2970
I have a MXL 9090 dual capsule condenser mic. One side is bright, the other is warm.
http://www.mxlmics.com/products/900_series/9090/9090.html
Recently, the warm side stopped working. The LED lights up which indicates that the phantom power is being supplied. The bright side works as normal. I don't think the diaphragm is busted because the mic makes no noise at all when that side is activated. I was just wondering if it would be worth it to take the mic apart and see if it can be repaired. I can solder and do almost anything else it would take but I just need to know how fragile those mics are to be worked on.
So either I take it apart and attempt to fix it, or I just live with one good side and not risk breaking it too.......
What do you think??
What do you think??
