Mic Pre's for AW4416
  • Thread starter Thread starter amt7565
A
amt7565
I live in an apartment- so I can't play anything loud. I have been trying to record using Sm57 for my electric guitar. But seems like the sensitivity is pretty low when I play at the volume I like. The level meters don't go more than 20dB on the level meter.
I like to know if getting an external pre-amp will help me here?
Can I play soft and still get a good level on the AW4416? I want a higher range. What pre's do you recommend if that will help? Let's assume I am playing accoustic guitars for comparison.
Thanks.
The pre's on my AW4416 sound pretty good, but they don't have a lot of gain.
An SM57 would not be my first choice for acoustic guitar, an SP B1 is in the same price range, have more output and sound better.
I have a Groove Tubes Brick, and it does sound better on some sources. But... the AW4416 pre's are pretty nice.
So you think if I get a SP B1, that would help with the gain? Do you have a AW4416 as well? I am only recording Electric guitar. But I want to be able to record at low volumes. Thanks
It is my understanding that it has more output. I picked it because it was cheap and well regarded. My AT4040 certainly has more gain than my Shure dynamics.
What amp are you playing? If it's a tube amp, it won't sound its best until the neighbors call the police. If it's not, you would do better with a up-to-date modeler than micing. I have heard some decent stuff out of the new Pods, and the V-amps.
I have a THD Univalve- so I get good saturation at low volumes. Pretty happy!
I am done with using modelers etc. Now I want to try tubes.
Thanks.
Thanks.
amen brother! i'd love to have one of those thd low watt heads. how's it sounding?
It's unbelievable man! Love this machine. To make it even quiter, I have order a set of new tubes. the possibilities on this thing are endless! The built in Hotplate is awesome.
I got mine from Avatarspeakers for only $659.00. Give it a try.
yea, i see they have a package deal when you buy a cab from them. i would love to snatch one of those but unfortunately, i'm going to be so fucking broke for good while. i just quit my job and am about to move to another state to join a house of musicians. i'll just have to work with what i have for awhile.
You've been on here long enough to realize that you need to plug the microphone into the XLR input on the AW4416, NOT the 1/4" line input. It would have also been in the manual, that little stack of papers (sort of like a small book) that came in the box. :)
The little stack of papers explains that the 1/4" inputs have mic pre's just like the XLR's.
Doah! So scratch my manual rant :D
But it's still like Recording 101 that microphones go into XLR inputs (unless they say Radio Shack or Realistic on them)
And you'd think (hope/pray) that someome who is able to buy a Yamaha AW4416 and has been here since 2002 would know that...
Some one from another forum also pointed out the problem. The manual does not mention the difference between the XLR and the 1/4". It simply states them as the same and the input was just a matter of choice on the cables. Even the block diagram does not show this.
As you might know the AW4416 manual sucks big time.
I am going to get an XLR-XLR cable today!
Thanks folks!
This was posted on another foum when I asked if there was a difference:
" as long as the connexion is balanced (XLR or TRS - tip /ring /sleeve = "stereo"- jack)there's absolutely no difference. if you use a XLR to TS jack cable(tip + sleeve = "mono"),the connection becomes unbalanced you're most likely to get hums and noises and lose 3 dB (which is a lot : 50% less ).
all this is for dynamic mics or battery powered electret mics, but if you use a condenser mic, you need to use the XLR for 48 V dc phantom power."
I am using XLR--TRS. So I guess it does not make a difference. I will get the cable anyway.
