F
flomman
Hi,
I purchased some recording hardware some time ago, and had some trouble. I lost confidence and put it all aside, but am now attacking it again. I am trying to record audiobooks, and I want to end up with something fairly high in quality. My equipment is as follows:
Heil pr40 mic,
Mackie ProFX8 USB mixer,
dbx 166xs compressor/limiter/gate (just purchased),
64 bit Windows 7 laptop,
Reaper.
The last time I tried doing any serious recording, I failed because I couldn't get rid of a persistent hissing. Also, the signal from the mic was so weak that the volume slider and the gain had to be turned to the max to get a semi-healthy looking wave form in the DAW. This only increased the hiss. I found out from Mackie about needing to turn the microphone recording level down in the sound properties. This did help the hiss (without fixing it entirely) but reduced the wave form even lower in the DAW. I couldn't find other information, so I gave up. A year or so later now, and I am getting back into it. I have found online many people complaining about the Mackie mixer, and I realise that I have to replace it. With this as background, here is my question:
What hardware should I get? I don't know enough about this kind of thing to find out myself. I need to be able to get the Heil pr40 into the computer, and I need to be able to process the signal through the dbx 166xs. What would be the best way to do this? I don't want hissing, and other added sound. If this means that I need to dump the laptop and use some other kind of recording device, so be it. I just don't know myself what to get, and so am turning here for advice.
Thanks in advance for your help!
Heil pr40 mic,
Reaper.
