metronome?
  • Thread starter Thread starter MartyMcFly
M
MartyMcFly
Please excuse me if this is a stupid question...
But is there a metronome anywhere in Pro Tools LE?
I know its a stupid question but I need to know...
Surley someone has to know the answer to this question...I know that cubase has one...Thanks again
Marty,
Dude, this is a horrible forum to ask PT questions in...they think we are all lepers or something because we don't use the Delta1010 and Sonor...
Anyway, here is your answer straight off the DUC... enjoy!
In order to produce a click, ProTools can use a sound module with proper configuration of the OMS Setup application. You have the ability to route the click from ProTools LE to trigger any device provided it has been defined in OMS. If you do not have any external sound modules, you still have the option to use the QuickTime Musical Instruments software synthesizer. This is a General MIDI, multitimbral sound module which is included with the Macintosh Operating System. In order to take advantage of this "virtual synthesizer," you need to enable its operation through OMS.
Launch the OMS setup application.
In the studio setup window, double click the QuickTime Musical Instrument icon and click the radio button next to the word "on". Click "Use Rock Drum Kit" checkbox .
Click the "OK" button, choose "save" from the file menu and quit OMS Setup.
In ProTools LE, select Click Options from the MIDI pull-down menu or double click on either the countoff or metronome button in the transport MIDI controls window.
Click and hold on the "Output" pop-up menu and select your destination device and channel. If using a General MIDI compatible synthesizer (such as QuickTime Musical Instruments) use channel 10, for this is the channel that contains all drum and non-pitched percussion sounds.
Select a note for the accented and unaccented beats via your MIDI controller or by typing in a note name with the Macintosh keyboard.
Once you have configured the parameters of the Click options window to your liking, enable the click by choosing "click" in the MIDI pull-down menu or highlighting the metronome button in the MIDI controls transport window.
If using QuickTime Musical Instruments, the sound generated will be outputted via the Macintosh Sound Manager (i.e. the internal speaker). However, in order to route this signal elsewhere in your studio (such as a channel on a mixer) you need to connect a cable from the stereo miniplug (1/8") jack located on the rear of the Computer marked with speaker icon.
If you want to route the audio thru the 001 outputs please refer to #8 of the FAQ for instructions on monitoring an Aux input.
