M
MatchBookNotes
I was wondering does it matter what kind of metal you use? Is there anything exta involved like shielding or anything?
Shielding just has to be conductive, right? I would think a metal pickguard would serve the same function as a foil-backed plastic one, as long as it's attached to the rest of the shielding for the cavity.
I think you actually need to isolate the pickkguard from the electronics so as not to cause grounding issues, actually - I could have sworn I read about a few DIY jobs where guys ran into that.
You could make ground loops because the pots' cases (likely grounded) will be connected to the pickguard. The same can happen with foil shielding on the back of plastic pickguard. I'd try connecting the pickguard to the ground, and if there were a problem, isolating the pots with plastic washers from the pickguard.
cool thanks for the clairty!
any ideas on a wholly metal guitar would be like? Could you have a metal neck with a fretboart attached somehow, what about a truss rod? or would it be best just to bolt on a wooden neck?
aluminium is a choice material then? i think maybe a metal semi-hollow electric might bea cool idea, i do know a fabricator.
