cellardweller
Does the below sound like a plausible explanation and fix for the problem I've had with my DD20 gigadelay in my Mesa solo 50 effects loop?
*EDIT* Just to clarify~ The implied fix being the ebtech 2 channel line level shifter.
As some may remember from previous threads, my dd20 makes a thud thud thud sound which increases in volume until it is unbearably loud! The "thud thud" is in time with the tempo.groovadelic over at boogieboard said:I think I know what it is and I have the same problem with my Line 6 DL4. The parallel loop is "Line Level" +10db. It is a hotter signal than "instrument level" effects (-4db) such as the Boss DD-20 and the Line 6 DL4. Line level is what is used for more of the rack effect processors that you would use produce a wet signal, using the parallel loop as the dry. The instrument level effects are those that you put on the floor designed to be compatible into the front end (preamp stage) of the amp - they are designed exclusively to rely on the "mix" control on the unit to mix the wet and dry.
The problem then is the amount of signal being sent out of the effects send. The quick fix, if this is the problem, is an Ebtech 2-channel line level shifter. This will convert line level into instrument level and vice versa.
I personally think the design of a line level parallel loop is worthless for most players. I plan on getting a line level shifter and velcro-ing it to the back-inside of the amp cabinet and plugging the amp send in channel 1 and return in channel 2 (+10db) and then plugging my delay pedal input in channel 1 and output in channel 2 (-4db).
