Drummer4Life05
Say Something Smart!
Why would you buy a "matched pair" of microphones, rather than just buying 2 of the same mic? What makes them "stereo matched" or a matched pair?
Thanks,
Justin
Thanks,
Justin
Originally posted by Harvey Gerst
Mics are quirky pieces of equipment. No manufacturer can guarantee absolute consistency for every mic, so they have a "window of acceptance", whereby any mic that can pass thru that window is considered "good" and anything that doesn't fit inside the window is rejected.
Imagine a 3 foot by 3 foot window, wide open, and you can see that a 35" circle would pass thru the window, but so would a 35" by 35" square. Both go thru the window, but they are certainly different from each other.
Humidity, machine adjustments, thickness variations, component tolerances, and even the mood of the assembler that day all play a part in determining the consistency and final sound of any one single mic. The differences we hear between "identical models" of a microphone can be broken down as follows:
1. Self noise
2. Frequency response
3. Sensitivity
In actual order of importance for matching, it would look like this:
1. Frequency response
2. Self noise
3. Sensitivity
Usually self noise can be separated into 3 broad categories:
1. Higher than normal
2. Normal
3. Lower than normal
After a manufacturer has broken the mics up into these three categories, they try to match the frequency response. That breaks down into about 5 categories:
1. Neutral
2. Slight bass boost
3. Slight treble boost
4. Slight mid boost
5. Slight treble AND bass boost.
What about dips? Well, a slight bass boost is close to the sound of a slight treble cut, so they sound pretty similar. A cut mid sounds similar to a slight treble and bass boost. Anyway, that gets the mics split up into 15 general categories.
They then look for mics in each pile with similar sensitivities, and they wind up with a bunch of matched pairs.
Now of course, the "matched pair that YOU would like to get would have low noise, neutral frequency response, and high sensitivity, but that's not the definition of a "matched pair" - it's a definition of the best "matched pair" in that particular batch.
Sensitivity can be easily matched using the channel trim pots, if the noise levels and frequency response are similar.
Frequency response is the most critical area, since any major differences will result in a screwed up image.
Let's assume two mics are identical in every way, except one of the mics has a narrow 3dB peak at 500Hz and the other has a dip at the same frequency. You have the mics set up in stereo and the guitar player plays a chromatic scale on the guitar.
Whenever the guitar player plays the note that corresponds to 500Hz, the image will jump over to whichever speaker is connected to the mic with a peak in it. It will shift 6dB to one side or the other. That can be very disconcerting.
Smaller differences are far less noticable and mic frequency matching within a dB or so is pretty damn good.
How companies match mics will vary from company to company. If their noise levels and frequency response are pretty consistent, sensitivity matching is all that's needed. I believe Earthworks considers frequency response to be most critical, and they will custom match pairs to within a 1/2 dB.
Personally, I'm most concerned with similar frequency responses, followed closely by similar self noise levels (but the similar self noise consideration would be less critical for drum overheads than for quiet acoustic guitar work).
As with most things, there's no one easy answer to this stuff.
