That's awfully loud, isn't it? That means peaks (explosions, music swells, car dealer commercials) would be approaching 105dBSPL. That's pretty dangerous territory. I doubt that I've heard any of my local theatres go quite that loud....unless you're talking SPL a meter in front of loudspeaker, maybe.
G.
Well, I have, which is why I don't like to go to theaters. And it's why I run my DVD player through a compressor
Actually I think a lot of theaters exceed 85dBSPL; I stuffed cotton in my ears to watch "Austin Powers", and I mean the dialog. But that is the THX standard, which is why this otherwise not-audio-aware student is asking for it.
Anyway, 105dBSPL not dangerous as a peak level. The OSHA standards are set based upon C-weighted RMS, not peak, and even then the standard for 105dBSPL is 1 hour exposure. Most loud peaks in a movie are LFE stuff anyway. And there is nothing to say that dialog has to be 85dBSPL; it should sound as it would in real life; the music would be closer to the -20dBFS reference level, probably with peaks at -6dBFS. That last 6dB of headroom wouldn't get used much.
(NIOSH thinks the exposure standard should be lower, more like 5 minutes, but in most films that's about how much peak time there would be. That would also mean that even quiet rock concerts would be banned!)
The important concept is that if a theater is calibrated to -20dBFS = 85dBSPL (which it is supposed to be), then if you don't mix to that, I think it is likely your dialog would be too loud!
That's because as the OP says, he is peaking at 0dBFS with a reasonable level. If he is used to doing rock mixes at -14dBFS RMS, and mixes the movie at the same monitor level, to a comfortable listening level in his studio, when played back in a theater it would be 6dB too loud. So I'm guessing the monitor calibration will result in the OP remixing the soundtrack to be quieter than it is right now . . .
Katz talks about this in his book.
