PDP
There once was a note
When using effects on the master buss is there a particular order ? I use a stereo enhancer,EQ, limiter, maximizer and dither in that order. its hard to tell if the order makes a difference other than that if your increasing gain after the limiter you get clipping. Also, is it better to just send the mix to a stereo track and then add the buss effects on that, rather than in one step?
