Seeker of Rock
Let us be unburdened by that which has been ?
Well, most of the equipment is now in place in my tracking/mixing space. I have some older cables to connect the rack gear to the board effects send/receives, but I want to get something better and am considering making my own. I am looking at the Neutrik NP3X or NP3C connectors and need some guidance on cable. This would be the same cable as if I were wiring up XLR connectors, correct, like a Starquad or similar?
I'm going to price everything out. I need about 20 cables, give or take. If I can save 40% or so I'll do it. If not, I may buy.
Also, I haven't soldered in about 20 years, and was never a seasoned solderer, but I figure it can't be too terribly difficult if I go the DIY route. I did a search on saw some links for wiring connections should I have questions. Sounds like you pretty much wire ring to ring, tip to tip, sleeve to sleeve consistently and that's it.
