Makin' it Hot on the DPS
  • Thread starter Thread starter ditnoj
D
ditnoj
Hey DPS 16 users:
I'm not getting the level on the CD's I'm burning off the DPS. My levels are reading like 80 to 90 percent with a few peaks. Are any of you using the DPS solo (ie without external pres, send and return of beefed up signal, etc) and getting good level on the CD's?
If so, I'd like to know what you're doing. I have been experimenting with bouncing my stereo mix through the compressor without compressing but upping the output db's. It has helped some and I'm not through experimenting yet, but I wanted to know if anyone had another approach.
D out ITNOJ
Hit the button right below "GLOBAL"... then bump up the output level to +6 or +12db.
Problem solved. ;)
(Remember to lower the Master Fader when you do this, 'cause it's gonna get LOUD)
THanks alot!
I've got some soundtracks to burn for some folk this coming week and will be trying out the "button below global"!
D out ITNOJ
