V
Vigilante
Gear nut
Hey guys, I got some good help around here so here is another question for you cause I don't know what exactly I need.
Okay, I have 2 floor speakers which connect via standard 2-wire speaker cable, or speaker wire, whatever it's called. (what is it called?)
I know these speakers need to be hooked to an amp of sorts, to drive them. But my question is, I am not using these speakers for anything, and they sound pretty good, so I want to hook them up to my Tascam US-122 outputs.
I'm not saying I want them as as a "real" monitor, it's not like that, I just want to hear what I record. Better them then some dinky headphones or the dinky speakers on my laptop. So then my question is how do I go from my 1/4" output jack on the 122, and amplify it, and convert to speaker wire? Is there some sort of simple, and small, amp that goes 1/4" on one end to 2-wire on the other to drive stereo speakers?
The other aspect is that, I'm sure the 122 pushes 'some' power out, but probably nowhere near enough to drive the speakers. Otherwise, can I get just like a strait 1/4" to stereo 2-wire as just an adapter? Or do I HAVE to have an amp? And if I get an amp, does that conflict with the amplified signal from the jack? Or perhaps, can I just go from line-out on the laptop (1/8") to an amp and then 2-wire?
Or let me simplify, I just want to use these 2 speakers as main output, how do I get the best sound? What product do I need?
As for the speakers, they have 3 drivers in them. That is, I don't know what they are or how many watts they are. But each tower has 3 speakers in it, like a 16" inch, 6", and 4" driver. The towers are about 3 feet tall. So whatever amp I buy, I want some options, so using this amp or whatever, I can use these speakers from different kinds of outputs. Like from a TV or DVD, or PC etc... Enlighten me.
So everybody, just put me on the right path please.
Thanks a ton
-vig
Thanks a ton
-vig
