Mackie 808M question
  • Thread starter Thread starter cellardweller
cellardweller
cellardweller
Does anyone have a Mackie PPM series 808M (powered mixer)?
I have the 808M, and am trying to record a drum machine's left and right channels simultaneously, but seperately (two seperate .wav files into my Fostex MR8) using the Mackie to boost my levels. The drum machine (a Zoom) has some pretty cool stereo effects I'd like to capture for a particular song.
How would this most easily (and safely) be acheived ?
I looked at the manual, but I am still clueless...HELP!!!
It looks like the easiest way is to plug your drum machine into two channels, and use the insert jacks on those channels as line outputs. You do this by using unbalanced cables and plugging them into the insert jacks only to the first click. It takes a little to get the feel for that, but play around and you will see what I mean.
The other way would be to use the tape outputs, but it is a mono mixer, and I doubt the tape outs are in stereo.
Thanx boingo, a couple of clarifications...
By unbalanced, I assume you mean only TS (not even sure if I have any)?
If I were to accidentally insert it too far (huh-huh) could it result in damage to my MR8? This is why I haven't experimented with this, and as I said, I'm not sure if I have any mono/unbalanced 1/4's.
Yea, I'm not too sure about that either, but I guessed that it would not assign the two channels to left and right...
Yup, tip/sleeve, like regular guitar cables.
You won't hurt anything by pushing the cable in too far. With a TS cable in to the first click, the signal is split, and the signal still goes to the main outs and your recorder. This is cool if you want to, say, record a live performance on individual tracks, or send a signal to an effects processor if you don't have aux sends, or in your case use the mackie to monitor what you are recording.
If you push it in all the way, the signal gets interrupted, and only goes through your TS cable. This will be fine, as I assume you are going to monitor on your recorder.
Thank You!
And yes, you are correct, I will be monitoring on my recorder. Usually when I am recording the cabinets are unplugged.
That's a very handy bit of knowledge, as far as the position of the plug affecting how I'm able to monitor.
Kinda confusing for me as to how this works exactly. Is the "insert" jack only for "outputting"? Or does this only depend upon which type of 1/4 you are using (TRS as opposed to TS)? i.e. to use the insert as an input you must have a TRS... :confused:
Thanks again for enlightening the ignorant! :D
cellardweller said:
Thank You!
The insert jack is like an effects loop on a guitar amp. It provides a point in the signal path to "insert" another piece of gear, most commonly a compressor, gate, or outboard EQ. So it has an out and an in. To use it as an out and an in, an insert cable is commonly used. It is TRS at one end, which goes into the insert jack, and the other end is two unbalanced 1/4" plugs, one out and one in, more commonly called send and return.
It's easy to understand in pictures. Here is a link to Mackie's hook-up guide. Scroll down to the picture of insert points. It's a pdf file, so you will need acrobat reader to see it. I am also bored, and have included a painful verbal description as well.
The insert jack has three contacts. One is the shield, or -, and the other two connect to carry the + part of your signal. When there is no plug in the jack, the two conacts carrying the + are connected, completing your signal. When you put a plug into the jack, it seperates those two contacts. So, yes, what kind of cable you use affects how the signal is routed. the two contacts need to be hooked together to complete the signal.
When you plug a TS jack in to the first click, the tip connects the two positive contacts, and provides two paths for the signal. One to your outboard gear, and one back to the mixer. If you push it in all the way, it connects those contacts but only provides one path for the signal, which is out to your gear. The path to the mixer is shorted.
I guess you could use a TS cable pushed in to the first click as an input, but there wouldn't really be a point. Each channel has a 1/4 line input way more suited for the task. Besides, if you did, you would be sending that input signal back up the signal path in the wrong direction, as well as the right direction. Not sure it would hurt anything, but it might, especially if it is a strong signal. If you needed to use an insert point as a direct in, I would use an insert cable and use the return section only.
p.s. I need to make one correction:
This should read "If you push it in all the way, only one path for the signal is provided, which is out to your gear. The path to the mixer is shorted." It's a small distinction, but in the contact is just shorted to ground, not connected and shorted.
You, sir, ROCK!!!!
I actually understood what you meant!
I usually have a brainfart, block, retardation, whatever, where I CAN NOT understand anything until I print and read, and then re-read it, except in this instance. :confused:
Let me know when you are bored again, I'm sure to come up with more issues you could easily (painfully!) address!
Thanks for the link, I am going to print it out, but my wifes printer is out of ink.
Dredging up an old thread...
Hey, I'm Dredging up an old thread, so I don't have to create a new one, for the same gear in question.
Hopefully you will bear with me...
I'm going to rent a bass from a local music store, and get only slightly raped in the process, which brings about the question;
Can I expect decent results running a bass guitar directly into my Mackie 808m? Do I need some type of preamp, or DI box to get decent results? I have a friend with a V-amp I could borrow, I've heard they are "decent" at least...
Probably a stupid question, I half suspect the answer, but as I said, hopefully you will bear with me... :o
Thanks.
800 posts and still every bit the n00b!!!
This has helped me immensely... bypassing the mixer has slightly minimized noise it seems...
does anyone have spare parts for a 808m? I broke a volume control on channel 8 and need a replacement.
