R
rio452001
I recently inherited a Mackie 24 track, 8 bus mixer, like this:
http://www.mackie.com/products/24-8bus/index.html
I currently record to 2 x Delta 1010s, using a variety of "pro-sumer" pre-amps (ART MPAs & DMPAs, DMP3s, BTDPs). I put the kick, snare & toms through inexpensive compressors just to help tame them a bit before they go into the system, using a patchbay between the line of pre-amps and the compressors. Otherwise, I record amps & vocals etc dry and do all effects (compression, limiting, eq etc) and mixing "in the box". For monitoring, I am currently taking stereo outs from my soundcard into a smaller Behringer mixer & then into headphone mixers, main monitors, and alternative monitors.
I'm mainly doing demos for my own bands, and occasionally other bands, and some locally distributed CDs etc. I'm not unhappy with the product I get, all things considered (including my own humble abilities). Here's a link to some mp3s: http://www.myspace.com/thehightidesrocknroll
My current thinking is that the Mackie board provides additional versatility and options, in conjunction with my current set up.
From a recording perspective, there are direct outs for each of the 24 channels in the Mackie, so it's no big deal to connect any individual channel from the Mackie directly into any part of my current system. So in effect, adding the board gives me 24 additional pre-amps/direct inputs, along with eq and option of outboard effects should I ever want them. It's not like I really need them-- generally, I'm recording 3 and 4 piece bands, and I've got enough inputs using my current pre-amps etc. It's more a matter of having different flavours, and different routing possibilities, that's of any interest to me.
Secondly, from a monitoring perspective, there are more monitoring options provided by the Mackie than my current little mixer-- it's easier to route different headphone amps, monitors etc through the outputs of the Mackie than my existing mixer. Otherwise, however, I think I would continue to mix "in the box", using Cubase and UAD and other plug-ins, and then burn the mixes/masters to CD etc.
I guess my first question is whether it's worth the bother-- i.e., should I forget about recording with the Mackie, stick with my current pre-amps, and just pack away the board until I'm ready to open my own club and need a mixer for the house PA system? Or, will it give me something I don't currently have, in terms of recording options?
I guess I'm just throwing up the question of whether it will really add much, and if so, how best to maximize it's utility.
, 'Stereo phone mix on mix-b for the band (optional phone mixes on aux, but seldom needed because--
phone mix.
