M20 vs LX20
  • Thread starter Thread starter jonmmartin
J
jonmmartin
What is the difference between these two machines. Does the M20 sound better?
Thanks for the comments.
The LX20 is the low end of the ADAT food chain and the M20 would be at the top of the chain. While I know the M20 has better converters, I'd bet you'd be hard pressed to hear the difference between the two. Now the LX20 is equiped only with RCAs forf the analog outputs (unbalanced, -10) where the M20 will have the capability of balanced, +4 outputs. This can have a big impact depending what you're driving it with and what you monitor with.
Thanks for the help...what about the XT20? Is it closer to the M20?
The other big difference between the M20 and the LX is the transport system. The M20 was designed for use in a production environment.... the LX20, not so much.......
The XT20 will have -10 and +4 ins and outs (the +4 on an ELCO connector) and will have slightly better converters. Also a beefier build in general.
