M-Audio Studiophile SP-5B Monitors
  • Thread starter Thread starter Phyl
P
Phyl
Guest
I used these monitors in my home studio for about 2 years. They are in excellent shape and have never been pushed hard. They are self powered so all you need to do is provide a line level signal from your mixer or other audio source. I'm selling them because I upgraded to an 8" set of monitors.
$100 plus shippping.
Here's the specs:
2-Way near field monitors 4th Order Linkwitz Riley Crossovers 1 x XLR Balanced Input Connector; 1 x TRS Balanced/ Unbalanced Input connector Polarity: Positive signal at + input produces outward LF cone displacement Input Sensitivity: 200 mV input produces full output with Input Sensitivity control at maximum. Input Impedance: 30k ohms balanced, 15K ohms unbalanced Protection: RF interference, output current limiting, over temperature, turn-on/off transient, subsonic filter, external main fuse. S/N Ratio: > 100dB below full output, 20kHz Bandwidth Frequency Response: 33Hz - 22kHz Crossover Frequency: 2.7kHz LF Amplifier Power: 42W HF Amplifier Power: 33W Indicator: Power ON/OFF indicator on front panel Power Requirements: Factory programmed for either 115V-50/6OHz, 23OV-50/6OHz or 100V-50/60Hz; Power via detachable 3-circuit line cord. Dimension: 250 mm (H) x 166 mm (W) x 200 mm (D)
Weight: 25 lb.
Want to buy SP-5B
Hi. This is my first time here and saw Phil's ad. How can I purchase your SP-5B monitors? Thanks.
