Middleman
Professional Amateur
Found this little note in the text file of the latest WDM beta driver from M-audio. Thought I would share. This applies to version 5.31 beta.
10-16-02 Updated Readme to posting on 10-15-02
Attention Delta Card User:
Very Important!!!
This BETA release of the WDM driver for Delta series
1) Does not have GSIF (GigaStudio Interface) support.
2) NO support for less than 10ms operation with WDM applications.
3) This driver can be loaded and used with Windows ME, improved WDM
support for use with Windows ME.
List of improvements:
1) This driver has improvements in the WDM architecture to fix
a reported bug concerning the amount of delay (track offset)
depending on the buffer size chosen in the delta control panel for
Sonar and WDM application users.
Audio recorded using these drivers is delayed relative to previously
recorded tracks. This delay has been reduced from 180 samples offset
to less than 10 samples on average.
2) Multiple card sync with ASIO applications and the Delta 44 without need
for external hardware SPDIF lock. This added feature is an advantage of ASIO
architecture. This is not available for WDM due to limitations within
WDM architecture.
3) Ravisent based DVD Decoders no longer experience loss of AV sync
when using Sonic Cineplayer or using the Ravisent decoder with Zoom Player,
Media Player 9 and other DVD decoders that can use the Ravisent decoder.
For the future:
An updated WDM driver is in the works, however the main point to this
beta driver being released as a service to those users wishing to obtain
improved decoder support with Ravisent based decoding software for DVD playback.
The professional series Delta card driver is in the works for the immediate
future. As this is a BETA driver and we wish to make this the most compatible
driver for audio recording, for the discerning pro-audio user, take this driver,
work with it and send your concerns with this beta release to testing@m-audio.com.
Your input is greatly appreciated in making this a better driver for the final
candidate release of this driver for the Delta series.
Thank you.
M-Audio
Testing and Engineering Team
Very Important!!!
WDM architecture.
For the future:
Thank you.
M-Audio
