A
amt7565
Folks,
I have an M-audio OMNISTUDIO(older model). I have not used this in a while.
Now after trying to record today there seems to be some problems. Perhaps someone can help?
Mixing latencey: There are big delays if I have this set to anything other 0. So now I have it at 0 and delay has decreased significantly, but there is still some minor delay in playback. This is making the music sound a bit hollow.
Buffer playback queue: 4
Buffer size 5.3 ms.
Sampling rate 96KHz/ 24bit. (sounds bad if I have it at 44.1/16bit)
Playback timing master: Multichannel 1/2
Record timing master 3/4
IO buffer size 64
I have "apply dither" enabled.
DMA buffer sizes are all set at 512
I have run the "wave profiler"
I have the synth outs connected to the Line3/4 of the OMNI.
Any suggestions will be appreciated.
Thanks.
Buffer size 5.3 ms.
IO buffer size 64
Thanks.
